Hello gurus!!
So I was wondering, how can I change the content from one element, let's say a Title inside my document opened in Arbortext Editor? I'm not sure at this moment which ACL command can I use for that purpose.
Thank you! ![]()
Paulette
Hi Paulette--
The easiest thing is to delete the old content and insert the new. Something like this should do the trick:
function replaceContent(oid, newContent) {
# where oid is the oid you want to modify, and newContent is a markup string you want to put there instead of what's there now
oid_delete(oid, 0x2); # 0x2 flag = delete element content, but preserve tags
goto_oid(oid);
insert(newContent);
--Clay
Hi Paulette--
goto_oid(oid);
insert(newContent);
--Clay
Clay,
Thank you so much. As always your help is more than appreciated and of course very very useful.
--Paulette
