Hi All,
Could you please help me on the following issue?
When I connect to Windchill server from Arbortext Editor, the "Eval output Window" appears.
Is there any way to disable it?
Thanks a lot in advance for your help,
Jérôme
Is there an eval statement in your siteprefs.xml or userprefs.xml file?
Hi Tim,
sorry for the very late answer... ![]()
There isn't any eval statement in my siteprefs.xml or userprefs.xml file.
Jérôme
Hi Jerome,
Obviously, this is not normal behavior, so you'll want to look into any custom files, ACL scripts and such, that you have installed on your system.
To help narrow this down, look into the following:
Do other users see the same window?
Do they use the same custom folders as each others?
