Dear All,
I have a question that how to set and change the side chapter number.
Can I editor or reset it? (The red square frame in the following image, it's the chapter number.)
How? In Arbortext Style?
Could you give me any tips please? Thank you very very much!!!
Best Regards
Lorin
In Styler, select a Page Set where the region is to occur.
Select the Add Region button and define the region.
Select the "Other" radio button rather tha "Main content flow"
Use the GoTo buttons to select the page type and use the Add button to add your newly defined region
Once all page types that need to be have had your region added, the select your region and select the GoTo button.
Define the Position of the region.
Define the Text if there is any (would be None or Generated text)
Define any graphic usage
Define any borders
Define any background, etc.
Have you looked at defining a Page Region for the header of a Page Set?
Have you looked at the styling of the title element in the context of a chapter, looking particularly at the Generate Text numbering?
Hi Tim,
//I can't find it. The location for all page region is the following except the main content region.
//I find these, but I'm not sure about it, I'm confused for it ![]()
Lorin,
You need to create a new region setting the parameters to the values that you require.
Hi Tim,
But I don't konw how to add the side chapter number? I can only add the page header and the page footer, but not the ![]()
thanks!
Maybe the question is how to set to parameters ![]()
Define any borders
Thank you Tim, I would follow and set it.
