I am having a problem with my underline element in that it is not underlining the hyphen if a word gets hyphenated at the end of a line. I know the scorespc="1" in this snippet <highlt scoring="1" scorespc="1" scorestyle="single"/"> makes the spaces and commas in underlined text be underlined as well as the actual text but is there any way to get the hyphen to be underlined as well? Any help would be greatly appreciated.
I tried your suggestion and the set wordincludechars trick and neither of them worked (but thanks for the suggestions!). I forgot to mention in my original post that we recently transitioned from 5.2 to 5.4 and in 5.2, we did not have this problem. We have opened up a Technical Support call on this and I will let you all know how it turns out in this thread. Thanks again for your suggestions!
In Reply to Suzanne Napoleon:
Hi Mike,
What version are you using? I tested the following in 5.3 and the hyphens are
underlined. A graphic is attached. I tried it with ragged right as well as
justified.
<highlt inherit="1" scoring="1" scorespc="1">
scorestyle is not a characteristic in the 5.3 Outspec DTD, so I'm thinking you
must be using 5.4. If you are, the release notes should mention the new
characteristic and hopefully provide helpful information. If not, contact
Technical Support. And please let us know what you find out.
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
