IDCAP limit
Newbie
IDCAP limit
I keep getting a warning that the IDCAP limit has been exceeded. It
says the maximum set value is 35000. I have changed the dcl file to
read 200000 and have recompiled all the fosis, but I still keep getting
the warning. I made sure the catalog file had the associated dcl file.
What am I doing wrong??? I am using Adept Editor 5.4.1.
Tags (2)
IDCAP limit
> From john.p.baklayan#064#boeing.com@mail.mdc.com Thu Feb 26 14:29:44 1998
...[snip]
Keep in mind that the FOSI itself is an SGML document. Possibly
you have to recompile the "outspec" dtd, probably under the "da/doctypes"
directory, otherwise under "doctypes". (I do not remember the
structure of the 5.4.1).
If you get the error above when you compile the fosi, it is a clear
indication of that the outspec has to be recompiled.
BTW, your FOSI must be very complex, I have not come close to the limit
as far I know.
Per-ÃÂ
ke
Per-ÃÂ
ke Ling (note: Per-Åke, transliteration Per-Ake)
email: Per-Ake.Ling@uab.ericsson.se phone: +46 8 727 5674
Ericsson Utvecklings AB mobile: +46 70 790 2446
AXE Research and Development fax: +46 8 727 3463
IDCAP limit
John:
We pushed the limits on almost all the settings in the dcl to 600000, when
we asked ArborText (of course this was several years ago) how high we could
go they didn't know. Just keep pushing it until you don't get the error
messages anymore.
Sue Peterson
Freightliner Corp.
