Karl, John Thank you so much for your help! 😃
Regards
Paulette Zorrilla
Clay! The eclipse integration sounds good, I will try to find more information about it, if I found anything I'll keep you informed.
Paulette Zorrilla
I've been using EditPlus for ACL work - http://www.editplus.com/
I have a syntax colouring file if anyone's interested...
When the acl customization is numerous andsome integration with Windchill. Eclipse plugin is convenient for project code management.
