Import few XML documents into ACM
aneder
8-Gravel
It looks it is impossibly to save few separate XML documents into Windchill by the only Save to Server or Check In. For example, if you have few DITA topics, but you have no map file, you should save separate documents into Windchill one by one. The same, if you have S1000D XML Data Modules you should open and save them to Windchill Server one by one.
Usually WGM technology proposes to upload all  source files from local disk to Windchill. But Arbortext cannot do it. The only possibility for Arbortext - to save root document with links to chield documents.
I believe such functionality like "import many XML files into Windchill" should be realized in Arbortext.
Alexander Neder
DanMarotta
(To:aneder)
Hello Alexander,
I think this post would be better suited as a Product Idea (formerly Enhancement Request) so other users can vote on it so that product management can prioritize it into a future release.
PTC Arbortext Product Ideas
A copy and paste of the above document should minimize any additional effort on your part.
-Dan
