Mark,
IF you can set hidesuppressed=on,I think the following should help.
You could code the screen FOSI to suppress a table when an ati:display attribute
is set to no. You would need to provide a menu item, toolbar icon, and/or
keymapping for authors to turn table display on and off. The screen FOSI would
display a message about how to toggle table display. It's an extra click for the
authors, but gentext update could still be set to full. (Standard disclaimer
here.)
Good luck!
Suzanne Napoleon
In a message dated 2/9/2006 11:51:21 A.M. Eastern Standard Time,
mark.cole@janes.com writes:
style="BACKGROUND-COLOR: transparent" face=Arial color=#000000 size=2>
face="Comic Sans MS" color=#800000 size=2>Lynn, Ed, Lupe,
face="Comic Sans MS" color=#800000 size=2>Our books are divided up by
Chapter,section and then each record in that section is an individual
XML document. We use Content@ as our XML repositoryand we tried in
the past to split the document up into entities but this was unpopular with
our users becausethey preferred to see the whole record they were
working on while editing and were also unable to manipulate the record the way
they wanted. Basically, they didn't have much flexibility in deciding
what order these entities would go in inside the record.
face="Comic Sans MS" color=#800000 size=2>We also have some books that are
just packed with tables, very large ones too. I would turn off automatic
update of generated text as Ed suggests but our users like to insert numbered
notes in our tables and link them to data in the table. In the past they
have kicked up a stink because the numbers weren't in sync (because generated
text was not updated automatically), they don't like the extra work of having
to click one more button on the toolbar. Finally, thank you Lupe for
suggestion but I also don't thinkmy userswill like the idea of
switching the tables into markup mode. They complain enough already
about how tables are displayed in Epic. This will just give them one
more reason to moan.
face="Comic Sans MS" color=#800000 size=2>Regards,
face="Comic Sans MS" color=#800000 size=2>Mark
Sent: 08 February 2006 18:36
To:
adepters@arbortext.com
Subject: Re: Improving performance in Epic
5.1
Mark,Are you working with the large document (I'll get to
tables in a minute) for editing or publication? If you are editing,
there are several ways to improve the performance, probably the best is to try
to modularize the document. Make chapters (or similar blocks) individual
files. Only bring all the pieces together for publication (or a QA prior
to publishing).
You can use
the DTD Fragment to do this. The markup resembles
this
The Fragment has to be inside a comment as does the
DOCTYPE declaration AND (repeat AND) so do any locally declared ENTITIES in
the declaration subset. Epic will then interpret the document making
believe any missing parent elements are present. The DTD fragment is an
OASIS TR and not an Arbortext extension like the PI
face="OEM Fixed" size=2>Pub CX milstd(front()body(>
Though Epic will insert one that emulates the path you are
currently in.By editing a smaller
chunk of you document, Epic does not have to parse, assign OIDs, generate
text, etc for the entire document and it will run faster.Now on to Ed's "Spawns of Satan" tables. You
could modularize your tables to be file entities as well and edit them with
the DTD fragment as well. However, if you have an extremely large table,
you may not be able to improve your performance and breaking a table down is
not something for the faint hearted I would not try it.
Lynn
