InsertAutoNested child elements
ptc-957266
Newbie
I'm using Epic 4.1.1
I want to insert an article with 2 child elements using the topic
"InsertAutoNested" in the ATD-editor.
Example:
<article>
<classification></classification>
</article>
Can I define this in the ATD-editor?
The construction
"InsertAutoNested:
article: title"
results in
<article>
</article>
How can I autoinsert the classification element as the second child
element of article?
Thanks for any advice!
Michiel Vanhoutte
Wolters Kluwer Belgium
Tags (2)
Re: InsertAutoNested child elements
Michiel,
Have you looked at the insert required tags set option? The option name
is set addrequiredtags which you can find in the online help's index.
Turning this on will enter any required tags. Now if title or
classification are not required, then there is a problem. Of course now
any other element that has required tags will also be added, so there are
some drawbacks. But this may be easier than trying to make the ATD file
work.
Remember one thing about the ATD file. If you make changes, you MUST
recompile your DTD or the changes won't show up.
I haven't messed with an ATD file in awhile and I don't have anyother
versions of Epic other than 5.1 installed on my system any longer. So I
really can't help on the ATD functionality.
Lynn
