I am trying to display <dd> and <dt> tag in definition list(DL) in arbortext editor. Main intention is to check the attribute values. Currently <dl> tag will show attributes when it is embbeded inside another <dl>. How can i enable for <dd> and <dt>
Roopesh
Try Arbortext Editor's menu pick View > Tables > Table Markup
Hi Roopesh,
Did Tim's answer help you with this?
Did you have any follow-up questions for the Community?
Actually my intention was to enable dt and dd inside dl without losing the table structure. I guess it is not posible.
Roopesh N
Hi Roopesh,
Maybe View>Tables>Cell Tag Display>Full Tags will do what you want.
Good luck!
Suzanne Napoleon
