Has anyone ever came accross this issue with IsoDraw Export?
Using IsoDraw I "placed" the tif, created leader lines/ callouts, and exported "as usual" to WebCGM 2.0...It seemed to export o.k. until I tried to insert into Arbortext Editor, and I noticed that only the leader lines/ callouts were showing
. I opened the CGM file-same thing "only callouts/lines" ....So I checked the original "IsoDraw" file and it still included graphic...So the problem must be at Export-but everything looks o.k.....Did I accidently change an advanced setting somewhere, or has there maybe been an update that is causing a conflict between software applications at export ![]()
Versions:
Arbortext Editor 5.3
Arbortext IsoDraw 7.1 ~~~~~Exporting to WebCGM2.0~~~~~~
Just a guess, but I'd suggest checking your layer window. I remember having some of our illustrators accidentally turning layer export off when locking/unlocking layers.
