All right gang please put your thinking caps I think I have a weird one. I create an IDR file with some hatching (See idr1.png). Then when I export the file out as a CGM (see cgm1.png) the hatching changes size on me. I tried to just scale the hatching up to the correct size but the quality is unacceptable. Anyone run into this before, and if so how were you able to correct the issue?
