My illustration looks great in IsoDraw, so I export it to WebCGM 2.1 for downstream processes. It looks great in the downstream process, but if I import the .cgm file back to IsoDraw it is missing line colors, line weights, leader-line halos, and area colors to name a few.
If you used contour shading to add colour you will need to select create contour fills on the camera button (2D button)
Bryon
Apparently I just needed to hit ctrl+k. What does ctrl+k do?
It shows a preview. I have attached a shortcut list. Hope it helps.
Bryon
