IsoDraw macro change_line_color
swillis-2
I need to change the color of a pen to....
Define Mycolor as ColorSpec
Mycolor.type = "rgbValues"
Mycolor.rgb.red = 255
Mycolor.rgb.green = 116
Mycolor.rgb.blue = 66
I found this......
activeDoc.pens["Thick"].color.type = "colorRef"
activeDoc.pens["Thick"].color.color = "Mycolor"
activeDoc.pens["Thick"].color.tone = 1
...but I'm confused about the syntax
any help most appreciated
Dutch_Mn
(To:swillis-2)
Try this
Macro pencolor
activeDoc.pens["Thick"].color.type = "rgbValues"
activeDoc.pens["Thick"].color.RGB = "{RGB 255 116 66}"
End Macro
Dutch_Mn
(To:swillis-2)
Try this
Macro pencolor
End Macro
yes......many thanks ....again
That has worked well!!
twade
(To:Dutch_Mn)
This macro works great if you always know the pen name, but is there a way to make it search all pens and change there color reguardless of the name?
BLArts
(To:twade)
This may help. This makes all pens that have names that start with 0 have a black color.
Macro Make Pens Black
DEFINE p AS Integer
	DEFINE i AS Integer
	DEFINE BkCr AS String
	Select None
	i = ActiveDoc.PenCount
	p = 1
#Starts loop that goes through all existing pens.
		While ((p <> i + 1) = True)
		If (Left(ActiveDoc.Pens[p].Name, 1) = "0") then
	BkCr = ActiveDoc.Pens[p].Name
	activeDoc.pens[BkCr].color.type = "colorRef"
	activeDoc.pens[BkCr].color.color = "Black"
	activeDoc.pens[BkCr].color.tone = 1
	p = p + 1
		Else
	p = p + 1
		End if
		End While
End macro
