since the installation of Isodraw 7.3, I have a problem with the selection rectangle which is not visible
The drawn objects are no longer visible until finishing the drawing of the object
Does someone know how to correct this ?
Thanks in advance
Regards
Corrected by unselecting Use OpenGL in the Preference menu (redraw)
Thanks to the PTC support
