Sure would be nice if I could use my Isodraw over a remote desktop. Is this possible? Tells me my License request has failed.
Bryon
Hello Bryon,
Referring to the CS10026 case you need a floating license: "Arbortext IsoDraw CADprocess configured to a locked license file can only be accessed from locally from the workstation".
We made a remix deal and switched from a locked license to the floating license. Now we can use IsoDraw via RDP. Our workstation config:
I hope this helps you further.
Kind regards, Anton
Has anyone tried a bat file to execute the exe through a RDP connection?
Bryon
Hello Bryon,
Kind regards, Anton
