Isodraw compatible with Windows 10
mmagallanes-rib
7-Bedrock
Greetings,
Does anyone know if Isodraw 7.2 is compatible with Windows 10? Or Isodraw 7.0 to 7.3 in general?
Thanks in advance
Arbortext IsoDraw 7.3 M060 supported Windows 10 (64-bit) OS.
Thank you, that's much appreciated.
I take that Isodraw versions prior to the 7.3 M060 release are not guaranteed to be compatible with Windows 10, then?
It is always better to use the latest service release, if such a possibility exists.
