Isodraw v7 issues
ptc-1201602
Isodraw v7 issues
Hi, This is the first port of call to see if anyone has any niggling problems when using Isodraw v7 m030/m050? The first issue is a general isodraw question relating to any version and that is when in Edit Image mode....... 1)..Is there any way to have an undo stage when in edit image, because if you do make a mistake, you either have to start again or fill in what you have just taken out. This has been possible in the past on other applications, so it would be good to see it in Isodraw? 2)..When working at close range (ie;6400%zoom)Isodraw stops responding after a couple of commands and hangs, until we either minimise/maximise the program a couple of times, this can be very frustrating when it happens several times in one session. 3)..Text screen blanks out background after the window has been removed, so have to refresh page to get drawing back is this a possible bug? 4)..Autosave dosn't work in until the page has been refreshed? 5)..Regularly getting a ~ in front of file which makes the user do a save as command through several menus, when this should be a simple select of one button? If anyone has experienced these issues i'd appreciate your response. Our Isodraw is running on a network and uses pref paths to enable the libraries/templates to be updated once rather than on each machine. regards russ trim
Hi Russell, some of your topics occuring here too ...
