Isoview and windows XP 64 bit
ptc-2095324
hello is Isoview supported on the windows xp 64 bit edition? it installs but does not seem display the drawing when viewed. thank you
Hi Carl, IsoView is not tested yet on 64 bit machines, i.e. 64 bit is not a supported plattform. Hence we can not offer a trouble shooting to you, sorry. regards, Christian
ok thank you for your reply. we have corrected the fault by modifying our code. it seems it will work within an embed or object tag but not in a frameset.
