We have just upgraded to 6.0 M020. Since doing so the XSL-FO stylesheets that we use to produce landscape pages are publishing the pages as PDFs upside down. The page is set up as a 11x8.5. Has anyone else experienced this type of behavior? I have tested this using Print Composer and PE Server I get the same results with both.
Thanks in advance for all your help.
Just go the official word from PTC. This is the work around:
"The Adobe PDF driver needs to be set up with a landscape letter page.
Adding the 11” wide by 8.5” tall page size to the Adobe PDF driver, Distiller will produce the desired result.
To do this, right-click on the Adobe PDF driver in the printers window and select properties. Then select Printing Preferences on the General tab, and go to the Adobe PDF Settings tab. There, press the Add button after “Adobe PDF Page Size” and add the landscaped letter page size. Set width to 11.0 and height to 8.5. Highlight whatever value appears in the Paper Names dropdown and give it a name like landscape, then select Add/Modify."
