Layout Question
byork
Layout Question
I am wondering if anyone has attempted to create a layout similar to the attached using styler.
Any ideas would be welcomed and many thanks in advance.
If you're using styler, I would set an attribute (such as outputclass0to manipulate the number of columns used to format the page set (on the Breaks tab).
You could put your text content in a section tag, then set the section to use three columns. Then place the image outside of the section tag so it spans the whole page.
I'm not sure you'll get exactly what's in your example PDF, but it should be close.
Hope this helps.
byork
(To:byork)
Brett,
Thanks for your reply I will give that some thought and a try.
Thanks again.
