Losing my namespace
todd.karr1
Losing my namespace
Adepters,
I'm converting our custom code to work with schema, for an unknown
reason when a document is opened the base namespace is dropped from the
root element, if the document is then saved and re-opened, as you can
guess, it is then nolonger associated with our customizations. Any ideas
as to whats wrong?
Thanks in advance.
Todd
Todd Karr
Web developer/Programmer
Adepters,
I should have said earlier, we're using 5.2, or about to. Our DTD effort
works with it, but schema presents the stated issue. I may just modify
the save function to force in the namespace before it saves, this isn't
a solution, but should get me to the next issue until I can find the
problem, or someone finds it for me 🙂
Thanks for the reply John,
