MS Word to Arbortext Editor
roryjakes
I do not have import / export license and need to get a very large Microsoft word file into 6.1 Arbortext Editor. I have tried to copy and paste and it changes everything into just text. Is there anyway for me to get the file into Arbortext editor and maintain the format. I found the following quote, "On the Windows platform, Servigistics Arbortext Editor enables you to copy content from other applications and paste the content into your document using matching markup from your document type. For example, assume you are authoring a DITA document and copy a bullet list in a Microsoft Word document. When you paste that list into your DITA document, it will be pasted with the appropriate ul and li tags."
Please help.
5 REPLIES 5
Yes, the smart copy & paste is meant to work as you describe. The trick is that, out of the box, I think it is only configured to work with DITA and Docbook. If you're using another type of DTD or Schema then it won't work. The basic usage is to copy from Word to your clipboard, then paste it straight into Arbortext. It won't get everything perfect, but it will give you a good starting point.
roryjakes
(To:GarethOakes)
Hi GarethOaks,
What do you mean by smart copy & paste?
Thank you,
Rory
roryjakes
(To:GarethOakes)
Thank you for your help. I cannot read the two articles you gave me links for as I don't have a support contract. I got a seat on the PTC University and am taking Editor courses. Again, I am trying to learn how to bring Microsoft word including graphics into Arbortext. You have helped. I have accepted as a solution your suggestions.
Thank you,
Rory
Thanks. BTW, if your organisation has purchased Arbortext then you should be able to get your PTC account added to the organisation group. That way you will get access to the support facilities such as the online help centers.
