Making figure titles appear below figures
Highlighted
Using Styler, what is the best method to ensure that figure titles appear below figures in a generated .pdf?
Thanks.
Tags (2)
Highlighted
Re: Making figure titles appear below figures
I assume here that you have a data model that allows figure titles to be
before or after or else only before and that you can't change your data
model. What I do is hid the figure title in it's normal location and
then regenerate it where I want it.
Steps are:
1. Create a user formatting element, maybe _ufe:FigureTitle for a name.
2. In Print/PDF, mark the figure title element to be hidden.
3. In Print/PDF, add a _ufe:FigureTitle in gentext after for your
figure.
4. In Print/PDF, use an XPath expression to get the context for the
figure title to use as gentext for the _ufe:FigureTitle.
As I have been telling people, "UFEs are your friend".
You can even do this same trick in the Editor but there is one drawback.
The displayed figure title is generated text which the Editor does not
let you edit directly and the actual figure title tag is hidden. You can
still edit the figure title tag by using the Document Map but this is
kind of indirect.
I discovered this trick when I was working on a stylersheet to use
AXDocBook for writing specifications. We wanted to use <revhistory> at
the chapter level but the datamodel says that <revhistory> is contained
in <chapterinfo> which is an optional tag which must come before the
tag for the chapter. So our revision histories were appearing
before the chapter titles, just wrong.
John Dreystadt
Director of Product Management
Arbortext
Highlighted
I don't really know much about Styler, because I never use it.
Generally, if the title occurs immediately after the figure, you don't
need to do anything except make sure that it has "block" formatting,
i.e. a text break before and after it.
If the title occurs before the figure, you need to save its contents as
a variable, and then generate text by placing that same variable after
the figure.
I know how to do this in FOSI and XSLT, but I do not know the buttons,
dialogs, field entries, etc. that you would specifically need for
Styler.
Highlighted
Oh yeah, I almost forgot: if the title is before the figure, you need to
suppress it there, in addition to saving the contents.
Highlighted
John,
I've always said that authors are sly, cunning and devious and bear
considerable watching. If there is away to get what they want from the
DTD, they'll get there.
I kind of borrowed this from the (seen it referenced as both) Army and/or
Navy officers manual from the 70's (the 1870's) the said "Enlisted men
are stupid, but extremely sly, cunning and bear considerable watching."
Being retired enlisted, I both resent and resemble that remark. 🙂
Lynn
