MathType support
RichardSteadman
MathType support
My understanding is that the support for MathType introduced in Arbortext 8.3.0 is not entirely complete (limitations for publishing?). Is there a description somewhere of what is supported or not supported?
And will the next release be more complete, and when would that be expected?
Richard Steadman
Hi Richard
In 8.3.0.0 we released the integration with Wiris MathType that allowed authors to use the MathType tool for authoring.
In 8.3.1.0 (April/May timeframe) we are intending to provide the first step in the publishing of the authored MathML. For HTML we will provide a method to pass the MathML through to the HTML for the browser to render (most browsers render MathML natively). For PDF we will pass the MathML through to the content processed by the APP DLL and use APP's MathJax library to render the MathML.
In 8.3.2.0 (approx November timeframe) we are planning to go a step further and provide an option to use a method of replacing the MathML in the content with images rendered by MathType. This will apply to both HTML and PDF outputs.
Arbortext does not ship MathType, it will be up to the customer to acquire that application.
I hope this clarifies the situation for you
Simon
6 REPLIES 6
Hi Richard
Simon
Hi Simon,
Thanks for the prompt reply and detailed information!
Richard
I found this information helpful, thanks for sharing this.
Hi Simon,
I just wanted to follow up and see if there is a more specific release date for 8.3.1 yet?
Richard
Hi Richard
The current schedule shows 8.3.1.0 planned for the end of May.
For MathML publishing, we have added stylesheet properties which allow users to specify the XML namespaces they wish to pass through to the renderer. For HTML, the renderer is the browser. For PDF, it will be the APP engine. For PDF, you will need to use a provided stylesheet module which will include property sets and APP user functions to generate images using the MathJax library. A sample will be provided as well as information for making it work.
I hope this helps
Simon
Thanks Simon, that's very helpful!
