Hi Cleo, the file size IsoDraw deals with is the total size in memory. Due to references in the IGES file it can happen that the consumed memory for that data grows substantially. You can check into it by monitoring the RAM with the task manager. The tweak Dan mentioned demands 4 GB RAM, I see that you installed 2 GB so far. Usually the available RAM is shared by the application data and the operating system. When having 4GB installed, Windows may take 2 GB of it. The mentioned tweak allows the applications to consume up to 3 GB of the 4GB however. You find more details about it by searching the internet for "Windows /3GB Switch", but as I said, it demands 4 GB of RAM being installed. regards, Christian
