Silly Question. How do I make an ordered list labelled a, b, c, rather than 1,2,3?
If you are using Styler, did you check the Details button on the Gentext tab of the element that has the numbering? There is a drop down for "Number Style".
Not yet using Styler. If I have to leave the labelling until the processing stage that's fine. Thanks for your help.
