PDF Bookmark creation: length of bookmark entries truncated
JurgenSchnurr
I have experimented with creating PDF bookmark entries.
Arbortext Editor truncates the length of the bookmark entries
after 65 characters.
There is no difference, if the PDF bookmarks are automatically
created or created by the stylesheet (Direct PDF feature).
Does anybody know how to change this behavior?
Is this a feature or known bug?
Jürgen Schnurr
Technische Dokumentation
Try creating an ACL in Publishing Engine's .../custom/init directory named
(or whatever name works for you in your environment, as long as it's an
ACL):
pdf_bookmark_clip.acl
In it, place the following command:
$main::pdf_bookmark_clip=128
Restart PE and see if that fixes your problem.
I think this was a bug that got fixed. But I can't remember the versioning
particulars. And I could be wrong, it may have been a feature all along and
we just had to get directed to the setting.
On Tue, Jun 5, 2012 at 1:32 AM, Juergen Schnurr
<juergen.schnurr@tanner.de>wrote:
> Hello,
> Thanks
> Jürgen Schnurr
Hello Paul,
thank you very much.
It works for both the automatic bookmark generation and
the stylesheet driven bookmark generation.
By the way I tried this on the client side publishing.
Am 05.06.2012 13:24, schrieb Paul Nagai:
> named (or whatever name works for you in your environment, as long as
> it's an ACL):
> versioning particulars. And I could be wrong, it may have been a
> feature all along and we just had to get directed to the setting.
> <juergen.schnurr@tanner.de <<a=" style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:juergen.schnurr@tanner.de">>">mailto:juergen.schnurr@tanner.de>> wrote:
> Hello,
> Thanks
> Jürgen Schnurr
Great! Glad it solved your problem.
On Tue, Jun 5, 2012 at 5:07 AM, Juergen Schnurr
> Hello Paul,
> ACL):
> On Tue, Jun 5, 2012 at 1:32 AM, Juergen Schnurr <juergen.schnurr@tanner.de<br/>> > wrote:
>> Hello,
>> Thanks
>> Jürgen Schnurr
As a side note...
If 128 characters isn't enough, the command can take a value up to 255. I think that's the maxium value, though.
