PDMLink Question
byork
PDMLink Question
Hello all,
We are working on implementing PDMLink 9.1 with Arbortext here and I have a question.
When you use the built-in object browser within Editor, the structure displayed follows the document structure.
[cid:image002.png@01CC47B6.3481BF00]
When you use the display the structure within PDMLink browser I can't seem to find the way to sort the same way. It seems to only want to sort numerically and not base on document structure.
[cid:image005.jpg@01CC47B6.34971BC0]
Does anyone know how to sort by document structure within PDMLink.
Thanks in advance,
Brian
Brian York
-<">mailto:->
Exmark Mfg. Co.
[The Next Lazer]
Brian,
Try adding line number to the view and sort by line number then name.
Mike
byork
(To:byork)
Mike,
I ended up using feature number. That seems to work ok.
[cid:image002.jpg@01CC47C7.FFA8AC50]
Brian
