PE Config Question - Lost Stylesheet Selection
ptc-3050150
A couple of weeks ago, apparently I fixed something that wasn't broken and don't have a clue what I did.
Clicking File | Compose | PDF File, the down arrow next to Stylesheet has gone grey on me.
I can no longer choose from half a dozen stylesheets on the PE.
The Config File down arrow still works.
It is there in the Print Composed dialog box and works fine.
Can anyone tell me what I did to make THAT happen? Or, better yet, how to make it give me the ability to select back?
Unfortunately the PE Config.pdf wasn't helpful.
John T. Jarrett
BAE Systems | Arbortext version 5.4 | LOGSA XSL-FO v 1.5
7 REPLIES 7
Sounds like you made a stylesheet association in the file for printing. That's Format | Select Stylesheets... and then in the dialog you didn't just pick one to use, but associated that stylesheet for printing.
HTH,
Steve Thompson
+1(316)977-0515
this option is set in the dcf file. it is an attribute at the top,
something about allowstylesheet selection,. this one bit me last year
- it seems composer doesn't read this but PE does. I couldn't figure
out why one I could select and the other I couldn't.
..dan
DCF file?
<options ...=" allowcomposestylesheetlist="yes" ...<br="/>
is boeing hiring?
_____
I'll give you a job myself if you just stop spamming the list!!
I was told by someone who checked his profile on ptcuser.org that this guy is a recruiter. Not that being a recruiter excuses the inept email practices.
Awesome. Yep, someone had uploaded a new dcf file and allowComposeStylesheetList="no" was right at the top!
Thanks!
John T. Jarrett CDT
Tech Writer II, Tech Pubs, ILS, Land & Armaments/Global Tactical Systems
T 832.673.2147 ext 1147 | M 512.736.7031 | -<">mailto:->
BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
www.baesystems.com
