I cannot open PTC Arbortext Advanced Print Publisher. License problem: The desired vendor daemon is down Requesting ArbotextAPPDesktop 7788@localhost: (-97)
I had this problem in 2016 and the PTC community solved it for me.
Imtools.exe
Start / Stop / Reread
Stop server
Start server
Server start successful
Now I have the same problem
But using the same solution does not now solve it.
Can anybody out there help me please?
Take a look this article - "Error message "License request failed for feature XXX: -97, The desired vendor daemon is down" is returned when trying to launch Application based on Flexlm/Flexnet license": https://www.ptc.com/en/support/article/CS26888
Did you update your license file? We have found in the past that you need to also update the license server when updating the license file.
Bryon
Best wishes
John Potter
Director & Editor-in-chief
European Rail Timetable Limited
Available to pre-order: Autumn 2023 printed edition, Four Seasons Bundle from Autumn. Available to order: August 2023 digital edition, Summer 2023 digital edition, Summer 2023 printed edition, Four Seasons Bundle, Rail Map Europe 3rd edition, 2nd revision and Europe by Rail 17th edition.
The only time you need to update your license file is if you are updating to a new major version of the software, like 7.X to 8.X.
Licenses need to generated from the ptc site. If you log into your support account there is a box that says popular tasks. Choose Manage licenses, this will allow you to generate a new license file.
Then you load the new license file with the lmtools. This is where the lmtools needs to updated to a newer version, so that it will read the new license file properly.
You can always put in a support ticket also https://www.ptc.com/en/support
Bryon
We have now discovered the host id of my pc has unexpectedly changed to 48-D2-24-18-05-DC (as in the attached log file) possibly due to a Windows update. The licence file lm_51333415.txt has the original host id 54-BE-F7-23-DC-DC. Please advise on obtaining a revised licence file.
John Potter
Is one mac address for your wireless card and one for your wired. Or are you using a docking station. You need to submit a case to license people.
Bryon
