I have installed a fresh copy of Windows XP on my PC and installed ISO Draw 6.0 as follows:
I’ve tried every combination when it comes to having the dongle removed or left in and still get the same error. I’ve also tried installing the latest Sentinel drivers but had no luck.
Any advice would be greatly appreciated.
I don't speak for PTC, but I would caution you that parallel port dongles are somewhat more sensitive and finicky than USB dongles.
Apparently it is possible to damage them by plugging or unplugging them with the computer powered up. I recall seeing these warnings when we had parallel dongles for another CAD package back in 2001 or so. Out of ten parallel dongles, 4 of ours died for unknown reasons.
Also, you may want to make sure your parallel port is enabled in the computer's BIOS, and that it is listed in the Windows XP device manager. I don't recall if these require bidirectional ports, but that could also be a problem. (PS/2 / ECP / EPP)
- Dale
Try to contact technical support PTC, creating a new "Case" here: http://www.ptc.com/appserver/cs/case/case_logger.jsp
