Parenthesis around numbers
ptc-5878511
Hi All,
I'm looking for guidance on adding parenthesis around numbers using FOSI. I have the numbering in the document, but for some reason can not figure out how to add the parenthesis around the numbers.
Jay,
Have you tried in your <savetext> or <usetext> using the syintax
\(\,thenumber,\)\
It is described in the Arbortext Editor's help topic
Savetext construction rule and usetext source syntax.
Best regards,
Tim
Jay,
\(\,thenumber,\)\
Best regards,
Tim
HI Tim,
Your solution worked great. Thank you for your help.
Jay
