Picture float to the top in columns
tamara.riehle
Ave!
I have a problem with the float of pictures.
I have a three column layout. The pictures should alway be on the top.
So far no problems.
But if I have a column break (for example of a new topic) the following
picture floats not in the same column to the top but to the first column
on the page.
What must I do that the pictur floats in the the rigth column? To set the
float inline is no solution.
Thanks for help
Tamara
5 REPLIES 5
Tamara,
What is your 'floattyp' in your <floatloc> set at? If it isn't "atcolbrk"
then try changing it and let us know. If it is then could you post some of
your FOSI code for the floats. Floats are tricky and the more info we get,
the better chance there is of resolving the problem.
Lynn
_____
Return Receipt
Your RE: Picture float to the top in columns
document
was Tamara Riehle/VFTIS/SPX
received
by:
at: 11/17/2003 09:41:19 AM CET
Return Receipt
document
was Janet Erickson/VFTIS/SPX
received
by:
at: 11/17/2003 09:11:36 AM
Hello!
I try the "atcolbrk" but than I have the problem that I have the same
picture three time on one page, instead of one and i get an overflow if
there a more diffrent picture on this page.
At the moment I have the combination page type: same and width:
column-wide and teh flatloc for element:name
And so far no solution.
Thanks for the help
Tamara
"Lynn E. Hales" <->
Sent by: owner-adepters@arbortext.com
16/11/2003 21:44
Please respond to
To
<adepters@arbortext.com>
cc
Subject
Ave!
I try to make a Forced Column Break. In the Architect the Forced Column
Break is shown but if I open the printpreview there is no column break.
What must I do that I also have a column break in the preview?
Thanks for Help
Tamara
