Port used by Arbortext?
JasonBuss
7-Bedrock
I know this is a bit of a goofy question, but does anyone know what port
number is in use when Arbortext reads or writes files from a regular
(non-HTTP/WebDAV) file system?
Trying some exception testing with Riverbed, and the admin asked me
which specific port is being used when Arbortext does read/write
operations.
-Jason A. Buss
Hi Jason--
I'm not sure, but if you're on a Windows network using standard network
access, it's probably 445, which is the standard port for Windows SMB
network communications.
--Clay
Clay Helberg
Senior Consultant
TerraXML
If you're using NetBIOS, you might also need 137, 138, and 139.
Clay Helberg
Senior Consultant
TerraXML
Ah, 137, 138, and 139, a fine trio of rapscallions. Reminds me of
ShieldsUp!! New laptop. Not running ZoneAlarm. Just set up a house to house
offsite backup for my parents. I'm going to go get a port scan 😉
