In version 5.3, I could set the stylesheet via the "set stylesheet="C:\fosi1.fos" command and then run "preview allpasses force" to print preview which provided me with a print preview using the chosen stylesheet with no interruption. This worked fine.
In 6.0, (M060), however, running the same commands, it now interrupts requesting I manually select the stylesheet via the Preview dialogue after running "preview". (even though I had set it)
Has this been resolved in a later patch ?
Andy
