Print Composer used with Epic V5.1 with Print Composer vs. 5.3 with Publishing Engine in Arbortext E
jgroves
3-Newcomer
I am currently using Epic 5.1 with Print Composer used as my document
composer. I will be forced to upgrade soon due to computer upgrades. I
have a maintenance contract for all of the S/W and licenses that I use. I
don't see Print Composer in the Download area. Does anyone know if I need
to purchase new print composing software to support the change.
John T. Groves
W R Systems, LTD.
2500 Almeda Ave
Suite 214
Norfolk, VA 23513-2403
Ph. 757.858.6000 ext 442
email: jgroves@wrsystems.com
But a Constitution of Government once changed from Freedom, can never be
restored. Liberty, once lost, is lost forever.
<john adams=" 1775=">
9 REPLIES 9
The installer for 5.2 and up includes it as an optional component that
you can check/uncheck, but it is still ehre.
I can't speak for higher than 5.3, but print composer is just an installable feature (that is NOT installed by default).
PTC would rather sell you a server based feature, but as long as we have the license for the client side print composer feature it should still be available.
[cid:image001.png@01CC4C60.09BBB650]
-Andy
\ / Andy Esslinger LM Aero - Tech Order Data
_____-/\-_____ (817) 279-0442 1 Lockheed Blvd, MZ 4285
\_\/_/ (817) 777 3047 Fort Worth, TX 76108-3916
ebenton
(To:jgroves)
Print Composer is a separately-licensed feature of Arbortext Editor. You can install it when installing Editor by selecting the "Custom" installation and selecting Print Composer from the subsequent list.
jgroves
3-Newcomer
(To:jgroves)
Andy
Thank you Andy, If I had opted to do a custom install, I would have seen it.
Thank you for the help, I really do appreciate it.
John
_____
I was able to buy a new licence for Print Composer 6.0, but only because I
already own Print Composer licenses. Otherwise, Publishing Engine is the only
option.
My understanding is there are vendors with Publishing Engine who will format
your documents for you, for a price, if you can't afford PE.
Suzanne
jgroves
3-Newcomer
(To:jgroves)
Suzanne
Thank you Suzanne, this is great to know information. I will make sure that
I never let my maintenance contract lapse again.
John
_____
John,
If you intend to use version 6 you might want to look into getting a concurrent licenses for Editor and Composer. Otherwise, when you try to remotely troubleshoot someone's installation you will find that the fixed licenses do not work as they did on versions below 6. PTC stuck us with the new FlexNet license manager that doesn't care if you have a fixed lincese on your machine and the remote machine. There is no other reason to pay 4 times more for a editor and andother 4x for print composer concurrent licenses that is going to be used only on one machine. Unfortunately PTC doesn't see it this way.
Good luck,
-Andy
jgroves
3-Newcomer
(To:jgroves)
Andy
Thank you for the heads up. I will let my contracts and IT people know.
John
_____
lfraley
(To:jgroves)
Again, you can still get licenses of Print Composer for 6.0 and there are
lots of options for PE. You just have to talk to the right folks.
Liz
