I have installed Editor 5.3 on a number of machines but I keep getting the following error on some computers:
" Arbortext Editor has no formatting capabilities. Can not print documents."
I have tried uninstalling and re-installing 5.3 but to no avail. We don't use Composer so it's just the Print Editor View function that I'm after.
Thanks in advance,
Ali
Thanks for advice on this issue everybody.
I have gone through this with one of my colleagues who was getting the error when trying to print. I got her to invoke the function
via the command line by typing "FilePrintEditor" as per Brandon's advice and the error disappeared. She was able to get a print-out.
This solution is similar to another one whereby the font display on screen would not print the size it was on screen when modified through the menus but would print the displayed size when set through the command line.
Very curious.
Thanks again guys. I will firstly try a command line solution before I bore you with my problem next time :))
