Problem with redisplay
Highlighted
Newbie
We are facing some problem with the display.
In our customized application whenver the caret moves inside the =
table , we run our own ACL scripts in which we invoke different toolbars =
and menu's.
After the toolbars and menu's appear the edit window gets blank =
which means it doesnt get refreshed.
We tried using the redisplay command but it doesnt solve the =
problem.
However if we put the response command instead of redisplay , it =
works fine.
Similarly when the caret moves outside the table , same thing =
happens.
=20
Thanks in advance
Anita Nagri
anitan@ggn.hcltech.com
Tags (2)
Highlighted
and menu's.
problem.
works fine.
happens.
=20
Thanks in advance
Anita Nagri
