Pub Engine trouble: Error return '0' from ACL DVI generator
ptc-2147850
Running Arbortext 5.3, M090 (recently upgraded). I'm unable to Print Preview or Compose to PDF a single document. Had no trouble with first draft. Turned on Track Changes, and problems ensued. When I try to publish/preview, I get this Asynchronous Composition Error:
562a2b2737
Working backward, this error appears:
562a2b2737
I resaved the doc under another name, accepted all changes and turned off Track Changes. Error still appears. I've searched the knowledge base and forums for variations on these messages, with no luck. Other documents publish/preview fine. All ideas much appreciated.
0 REPLIES 0
