Publishing Engine and Advanced Print Publisher
byork
So I can't remember if I have the standard Arbortext publishing engine do I also have Advance Print Publisher or is there a separate charge for the Advance Print Publisher?
Thanks in advance.
SimonTaylor
(To:byork)
Hi Brian
From Arbortext 5.4 you had access to the APP print composition engine from PE/Styler. This isn't the full Desktop application, but is a DLL of the composition engine. APP understands Styler stylesheets, and you can also tell PE/Styler to use native APP templates (as long as you have developed them with this process in mind). This DLL is a standard part of the PE install and does not incur any additional cost. You can save out APP documents from the Print Preview if you wish and open those in APP Desktop.
If you want the Desktop, Server or Enterprise versions of APP, then these are separate applications and therefore must be bought separately.
Hope that helps
Simon
SimonTaylor
(To:byork)
Hi Brian
Hope that helps
Simon
byork
(To:SimonTaylor)
Simon,
Thanks for the info it was very helpful.
Brian
