Hello All,
While Installation of editor, it ask for the Publishing Server - If I do not have Arbortext Publishing Engine - What should be the option ?
- Can I get the trail version for Publishing engine only - it comes with Windchill server only ?
- Can I use the DITA OTK / Configure the OTK , if yes , how to setup /configure ? OR bydefault comes with the setup.
Thanks - MVK
If you do not have Publishing Engine then you cannot use the integrated publishing features of Arbortext.
1. Publishing Engine does not require Windchill, it is a standalone servlet application running on top of Apache Tomcat. No publicly available trial that I know of. You may be able to ask your PTC representative or reseller if you can get a special 30 day test license.
2. DITA Open Toolkit is not integrated with Arbortext.
-Gareth
-Gareth
Did your question get answered, or do you have further questions?
- Tim
