Publishing a single topic with profiles on APE creating orange page
bfriesen
18-Opal
We have a weird issue. We can send a ditamap publish job with profiles to APE and it publishes as expected. If we send a single topic with profiles we get an orange page, and an error message. From what I can tell from the error message, is that it does not know which pageset to use. Everything works as expected with print composer.
Bryon
<Record date="Thu Sep 24 08:48:33 CDT 2020" millis="1600955313692"
severity="warning" suppress="0" thread="main">
<Level>WARNING</Level><Message>Cannot find profile attribute corresponding
to "Product", profiling may not work correctly.</Message>
<Context
class="com.arbortext.epic.saxfilter.profile.ParseLogicalExpression"
lineNumber="288" method="parseProfileRef"
systemId="ParseLogicalExpression.java"></Context>
</Record><Record date="Thu Sep 24 08:48:33 CDT 2020"
millis="1600955313911" msgid="A50756" severity="warning" suppress="0"
thread="main">
<Level>WARNING</Level><Message>Top-level element profiled out for
document "C:\Program Files\Apache Software Foundation\Tomcat 8.5\temp\activeTransactions\rq_4592\source\x4.xml".</Message>
<Context class="com.arbortext.epic.saxfilter.ServerProfiler"
lineNumber="402" method="startElement" systemId="ServerProfiler.java">
</Context>
</Record><Record date="Thu Sep 24 08:48:37 2020" millis="1600955317"
severity="info" suppress="1">
<Level>MESSAGE</Level><Message linkname="LINK">*** APP Publish</Message>
severity="error" suppress="0">
<Level>ERROR</Level><Message>Pg 1 New page sequence not specified;
used fallback 'defaultPage'. [1035] (1:"editorDom0"#{2;/})
</Message>
</Record>
Thanks to Tim P @ PTC Support. He found the issue, I was missing a reference to my profiling pcf file from my copy of the dita-base-module.dcf. All seems to working as expected.
Bryon
Forgot to mention that if I do not choose any profiles when publishing an individual topic, it also publishes a pdf. Just without any profiling.
Bryon
Bryon
