Question about PDF search indexes
ptc-953926
Adepters:
Some of our deliverables are in the form of PDF collections (dozens of PDFs that can be launched from a Web page). We generate these using PE 5.3, direct-to-PDF. The group that maintains the PDF collection has a manual process for generating a PDF search index of the entire collection using the standard Acrobat tool. This, of course, is a manual and somewhat arduous task. So, I'm being asked if there's any way to automate this process (building the Acrobat search index). I'm pretty sure PE can't help - at least I couldn't find any mention of that in the PE Programmer's Guide, so I'm wondering if any of you have created these indexes and perhaps found a better method (automating the Acrobat tool, third party software, etc.)?
Thanks in advance,
Dave
Hi David--
DMP might be of use here. If you build a DMP project that includes all
your PDFs, it will build a full-text search index as part of the DMC
package it generates. You can search within DMC viewer of course (or in
the web app if you produce a webapp.jar file). But the index it
generates is a standard Lucene index, so you may be able to extract the
index part of the DMC build and integrate it with your own search
interface, assuming that interface also uses a Lucene-compatible index.
The PDF's you index this way do not need to be published using PE or
Arbortext (though of course they can be).
--Clay
Clay Helberg
Senior Consultant
TerraXML
