Quick FOSI Question
berard
Quick FOSI Question
We haven't had to change our FOSI in years (aside from slight
modifications) so I'm a bit rusty.
I'm hoping someone might be able to answer this quick question before
I inevitably figure it out.
Given two elements:
<problem id="p_123"><para>This is some
text</para><some-other-elements-here/></problem>
and
<problemref linkend="p_123">
I would like to have the para text from the ID node shown after the
problemref element in Arbortext.
I setup my fosi as follows:
<e-i-c gi="problem">
<charlist charsubsetref="block">
<indent leftind="@12pt" firstln="*"></charlist>
<att>
<specval attname="id" attloc="problem" attval="#ANY">
<charsubset>
<savetext textid="xref-formatted.txt"&lt;br"/>conrule="<problem.fmt>,#CONTENT,</problem.fmt>" xrefidtag="problem">
</charsubset>
</att>
</e-i-c>
<e-i-c gi="problemref">
<charlist inherit="1" charsubsetref="inline"></charlist>
<att>
<specval attname="linkend" attloc="problemref" attval="#ANY">
<charsubset>
<usetext source="#XREF(linkend,xref-formatted.txt)"></usetext>
</charsubset>
</att>
</e-i-c>
Now, the issue I'm having is that #CONTENT gives me all text within
the problem, but I really only want the text within the para. Is
there a simple way to just pull the <para> text?
Thanks in advance,
keith
6 REPLIES 6
SindyYoung
2-Explorer
(To:berard)
Give the para tag an id. The xref out to it. You may have to have two xrefs but it should work.
berard
(To:berard)
That's certainly an option, but it might be more tricky since we use
<para> tags all over our content, and there would have to be some ACL
overhead to strip the IDs if copied/pasted into a different context.
As the model works today, when the user tries to insert a <problemref>
tag, they are presented with a dialog that shows all available
problems.
I was hoping there might be more of an xpath-like way to extract just
the content I need.
keith
On Fri, Nov 12, 2010 at 12:58 PM, Young, Sindy R
Keith,
In your <e-i-c> I'd change the 'gi' from "problem" to "para" and then add a 'context' of "problem". That should gather the text of the paragraph contained in the problem
Lynn
> problems.
> the content I need.
> keith
berard
(To:berard)
Aah, perfect!
I stare at "e-i-c" all day, and seldom think to expand it out to
"Element in Context", which does exactly what I need.
keith
SindyYoung
2-Explorer
(To:berard)
Good eye Lynn
Sindy,
Thanks.
I'll take FOSI to FO ANY DAY OF THE WEEK. 😄
Lynn
---- "Young wrote:
> Good eye Lynn
