Quick way to restore thick and thin in curves in Isodraw?
TimSharp
Does anyone know if there is a quick way of changing curves back to thick and thin if they have been converted to single thickness?
You can get thick and thin back using F12 but it converts arcs back to ellipses so you have to cut them out again.
Hi Tim,
Whilst the elipse/curve is selected, hold down ALT on the keyboard and double click the segment between the small red squares with your left mouse button.
I hope that answers your question.
Alan
TimPhelps
(To:TimSharp)
Has any one else had experience with needing to change line thicknesses?
Hi Tim,
Alan
TimSharp
(To:aporter)
Thanks for your answer. It works - the only caveat is that if it's a grouped item, you have to ungroup it first or it doesn't work as expected. It's way bettrer than having to convert curves back to ellipses, then cut them back again.
