Reduced CGM Graphics using PE Server
SarahPrice
7-Bedrock
Whenever I try to print preview or compose to PDF using PE Server my cgm graphics come out reduced about 75%.
I'm using Arbortext 5.2 M020. Is anyone else had this problem? Is there some type of configuration setting that I'm missing.
Sarah
If you are using PDF Direct (or is it Direct PDF?), you can have some
control over graphics through the .pdfcf file. I forget which document
details the available controls, but if you search the documentation for
"pdfcf" you should be able to find it pretty quickly.
If you're using Distiller the above does not apply. At least not exactly ...
there may be similar controls available through an Adobe job options file.
I'm using Distiller. The Direct to PDF method significantly reduces the quality of our CGM graphics.
Sarah
