Refresh generated text with ACL?
ptc-925411
Sometimes when I'm inserting elements using ACL, the gentext doesn't update until I manually click the Update GenText button. I didn't see an ACL command that does the same action as the button, but I'm sure there must be one.
Does anyone know how to do it?
Steve
Hi Steve--
ShowGentext should do the trick.
--Clay
Clay Helberg
Senior Consultant
TerraXML
Interesting Clay, I'll have to try that.
We had some problems with refresh as well, so now I have a method that
calls the following two:
set gentextcurrent=off
set gentext=on
- keith
The following two may also "play" nice.
Redisplay
RevertStylesheet (an alias for the stylesheet_revert() function)
