Remove automatically all the <emphasis> tags
dgopois
I would like to automatically remove all the <emphasis> tags in my document with an ACL function (or other means). Do you have a solution ?
To remove all <emphasis> elements from a document open in Arbortext Editor, copy the following commands and paste them at the command line:
     find  -m '<emphasis>'; while ($status==0) {delete_tag; find -m '<emphasis>'}
Good luck!
Suzanne Napoleon
"WYSIWYG is last-century technology!"
Good luck!
Suzanne Napoleon
Hi Suzanne,
Thank you for your help.
FYI: You can enter help find and help delete_tag at the command line to display detailed Help information about these commands.
