Removing Entity after pulling in the text
rodney_o_german
When using Arbortext 6.0, can you remove the entity files from the XML file after pulling in the text from the entity?  Basically using entities to share content and upon publishing remove all entities and keep the content.  Which basically flat files the xml file.
Yes, Arbortext is able to flatten files in this way but it's not available through the menus. You would have to write a small script to do the work. Look up the doc_flatten function in the Arbortext Help Center.
Here is my script
set Arbortext="same as below"
for %%i in (*.xml) do (
"C:\Program Files (X86) \PTCArbortext Editor\bin\x86\editor.exe" -c -b "doc_flatten all undeclared" %%i
I cant get the changes to save to each file.
Ignore the d in undeclared.  I couldn't get copy and paste to work.  I mistyped above.
